The specified interface could not be created in the IS-IS database. As a result, the interface will not work properly with IS-IS.
If there is no other log message indicating that the vlan name was not found, the switch may be running low on memory.
Warning
Failed to create %ifName%
| Name | Type |
| ifName | String |
